atmNutWallFunction boundary condition provides a wall constraint on the turbulent viscosity, i.e. nut, based on the turbulent kinetic energy, i.e. k, and velocity, i.e. U, for atmospheric boundary layer modelling.atmNutWallFunction condition inherits the traits of the nutkWallFunction boundary condition.Required fields:
nut | Turbulent viscosity [m2/s] k | Turbulent kinetic energy [m2/s2]
The boundary condition expression is (([63], Eq. 6-7), ([71], Eq. 7), ([80], Eq. 25)):
\[ \nu_{t_w} = max(\nu_{t_w}^\prime, 0) \]
with
\[ \nu_{t_w}^\prime = \frac{ \tau_w y}{max( u_p, \zeta )} - \nu_w \]
\[ \tau_w = {u^*_{u_p}} {u^*_k} \]
\[ u^*_{u_p} = \frac{\kappa u_p }{\ln \left( max (E^\prime, 1 + \zeta) \right)} \]
\[ E^\prime = \frac{y + z_0}{z_0 + z_{0_{min}} } \]
\[ u^*_k = C_{\mu}^{1/4} \sqrt{k} \]
where
| \( \tau_w \) | = | Characteristic wall shear stress [m2/s2] |
| \( u^*_{u_p} \) | = | Local friction velocity based on near-ground velocity [m/s] |
| \( u^*_k \) | = | Local friction velocity based on near-ground k [m/s] |
| \( u_p \) | = | Magnitude of near-ground velocity field [m/s] |
| \( y \) | = | Ground-normal coordinate [m] |
| \( z_0 \) | = | Surface roughness length [m] |
| \( z_{0_{min}} \) | = | Minimum surface roughness length [m] |
| \( \zeta \) | = | Small value to prevent floating point exceptions [-] |
<patchName>
type atmNutWallFunction;
z0Min 0.001;
z0 uniform 0.001;
kappa 0.41;
| type | Type name: atmNutWallFunction | word | yes | - |
| z0 | Surface roughness length [m] | PatchFunction1<scalar> | yes | - |
| z0Min | Minimum surface roughness length [m] | scalar | yes | - |
Source code
