atmNutkWallFunction boundary condition provides a wall constraint on the turbulent viscosity, i.e. nut, based on the turbulent kinetic energy, i.e. k, for atmospheric boundary layer modelling.atmNutkWallFunction condition inherits the traits of the nutkWallFunction boundary condition.Required fields:
nut | Turbulent viscosity [m2/s] k | Turbulent kinetic energy [m2/s2]
The boundary condition expression is (based on ([24], Eq. 5)):
\[ \nu_{t_w} = \nu_w \left( \frac{y^+ \kappa}{\ln \left( max (E^\prime, 1 + 10^{-4}) \right) } - 1 \right) \]
with
\[ u^* = C_\mu^{1/4} \sqrt{k} \]
\[ y^+ = \frac{u^* y}{\nu_w} \]
\[ E^\prime = \frac{y + z_0}{z_0} \]
where
| \( \nu_{t_w} \) | = | Turbulent viscosity [m2/s] |
| \( y^+ \) | = | Wall-normal distance in wall units [-] |
| \( z_0 \) | = | Surface roughness length [m] |
<patchName>
type atmNutkWallFunction;
z0 uniform 0.001;
boundNut false;
Cmu 0.09;
kappa 0.41;
| type | Type name: atmNutkWallFunction | word | yes | - |
| z0 | Surface roughness length [m] | PatchFunction1<scalar> | yes | - |
| boundNut | Flag: zero-bound nut near wall | bool | no | false |
| Cmu | Empirical model constant | scalar | no | 0.09 |
Source code
