kLowReWallFunction boundary condition provides a wall constraint on the turbulent kinetic energy, i.e. k, for low- and high-Reynolds number turbulence models.kLowReWallFunction condition inherits the traits of the fixedValue boundary condition.Required fields:
k | Turbulent kinetic energy [m2/s2]
The model expressions for k for viscous and inertial sublayers are switched in a stepwise manner:
\[ k = \max(k_{log} u_\tau^2, \zeta) \qquad if \quad y^+ > y^+_{lam} \]
\[ k = \max(k_{vis} u_\tau^2, \zeta) \qquad if \quad y^+ <= y^+_{lam} \]
with
\[ k_{log} = \frac{\ln (y^+) C_k}{\kappa} + B_k \]
\[ k = \frac{2400 C_f}{C_{eps2}^2} \]
\[ y^+ = \frac{u_\tau y}{\nu_w} \]
\[ u_\tau = C_\mu^{1/4} \sqrt{k} \]
\[ C_f = \frac{1}{(y^+ + C)^2} + \frac{2 y^+}{C^3} - \frac{1}{C^2} \]
where
| \( k_{vis} \) | = | k prediction in the viscous sublayer |
| \( k_{log} \) | = | k prediction in the inertial sublayer |
| \( y \) | = | Wall-normal height [m] |
| \( y^+ \) | = | Estimated wall-normal height of the cell centre in wall units |
| \( y^+_{lam} \) | = | Estimated intersection of the viscous and inertial sublayers in wall units |
| \( u_\tau \) | = | Friction velocity [m/s] |
| \( \zeta \) | = | Small value to prevent floating point exceptions |
<patchName>
type kLowReWallFunction;
Ceps2 1.9;
Ck -0.416;
Bk 8.366;
C 11.0;
| type | Type name: kLowReWallFunction | word | yes | - |
| Ceps2 | Model coefficient | scalar | no | 1.9 |
| Ck | Model coefficient | scalar | no | -0.416 |
| Bk | Model coefficient | scalar | no | 8.366 |
| C | Model coefficient | scalar | no | 11.0 |
fixedValueFvPatchFieldnutWallFunctionFvPatchScalarFieldCmu, kappa, and E are obtained from the specified nutWallFunction in order to ensure that each patch possesses the same set of values for these coefficients.Source code
