nutUWallFunction boundary condition provides a wall constraint on the turbulent viscosity, i.e. nut, based on velocity, i.e. U, for low- and high-Reynolds number turbulence models.nutUWallFunction condition inherits the traits of the nutWallFunction boundary condition.Required fields:
nut | Turbulent viscosity [m2/s]
The model expressions:
\[ \nu_t = f_{blend}(\nu_{t_{vis}}, \nu_{t_{log}}) \]
with
\[ \nu_{t_{vis}} = 0 \]
\[ \nu_{t_{log}} = \nu_w \left( \frac{y^+ \kappa}{\ln(E y^+)} - 1 \right) \]
\[ y^+ = \max \left( 0, \frac{\kappa_{Re} y^+_{lam}}{1 + \ln(E y^+_{lam}) } \right) \]
\[ \kappa_{Re} = \frac{\kappa u_p y}{\nu_w} \]
where
| \( \nu_t \) | = | Turbulent viscosity [m2/s] |
| \( \nu_{t_{vis}} \) | = | \(\nu_t\) computed by the viscous sublayer assumptions [m2/s] |
| \( \nu_{t_{log}} \) | = | \(\nu_t\) computed by the inertial sublayer assumptions [m2/s] |
| \( y^+ \) | = | Estimated wall-normal height of the cell centre in wall units |
| \( E \) | = | Wall roughness parameter [-] |
| \( y \) | = | Wall-normal height [m] |
| \( f_{blend} \) | = | Wall-function blending operator between the viscous and inertial sublayer contributions |
<patchName>
type nutUWallFunction;
| type | Type name: nutUWallFunction | word | yes | - |
correctNut() (called through turbulence->validate) returns a slightly different value every time it is called. See nutUSpaldingWallFunction.Foam::nutUWallFunctionFvPatchScalarField::calcYPlus function for the details on how \(y^+\) is computed.Tutorial
Source code
