omegaWallFunction boundary condition provides a wall constraint on the specific dissipation rate, i.e. omega, and the turbulent kinetic energy production contribution, i.e. G, for low- and high-Reynolds number turbulence models.omegaWallFunction condition inherits the traits of the fixedValue boundary condition.Required fields:
omega | Specific dissipation rate [1/s]
The model expressions:
\[ \omega_{vis} = \frac{6 \nu_w}{\beta_1 y^2} \]
\[ \omega_{log} = \frac{\sqrt{k}}{C_\mu \kappa y} \]
\[ G = w (\nu_{t_w} + \nu_w) |\vec{n} \cdot (\grad{\u})_f | C_\mu^{1/4} \frac{\sqrt{k}}{\kappa y} \qquad if \quad y^+ > y^+_{lam} \]
where
| \( \omega \) | = | Specific dissipation rate [1/s] |
| \( \omega_{vis} \) | = | \(\omega\) computed by the viscous sublayer assumptions [1/s] |
| \( \omega_{log} \) | = | \(\omega\) computed by the inertial sublayer assumptions [1/s] |
| \( w \) | = | Cell-corner weights [-] |
| \( y \) | = | Wall-normal distance [m] |
| \( \nu_{t_w} \) | = | Turbulent viscosity near wall [m2/s] |
| \( \vec{n} \) | = | Face unit normal vector [-] |
| \( \u \) | = | Velocity [m/s] |
The omega predictions for the viscous and inertial sublayers can be blended by six different methods:
stepwise | Stepwise switch (discontinuous) max | Maximum value switch (discontinuous) binomial2 | Binomial blending (smooth) n = 2 binomial | Binomial blending (smooth) exponential | Exponential blending (smooth) tanh | Tanh blending (smooth)
G predictions for the viscous and inertial sublayers are always blended in a stepwise manner, and G below \(y^+_{lam}\) (i.e. in the viscous sublayer) is presumed to be zero.
The viscous and inertial sublayer estimations of omega are switched between each other depending on the \(y^+\) value of the point of interrogation.
\[ \omega = \omega_{vis} \qquad if \quad y^+ <= y^+_{lam} \]
\[ \omega = \omega_{log} \qquad if \quad y^+ > y^+_{lam} \]
where
| \( \omega \) | = | \(\omega\) at \(y^+\) |
| \( y^+ \) | = | Estimated wall-normal distance of the cell centre in wall units |
| \( y^+_{lam} \) | = | Estimated intersection of the viscous and inertial sublayers in wall units |
The maximum value of the viscous and inertial sublayer estimations of omega is set as the omega estimation at \(y^+\) ([62], Eq. 27).
\[ \omega = \max(\omega_{vis}, \omega_{log}) \]
The omega estimation at \(y^+\) is blended between the viscous and intertial sublayer estimations by using a binomial function ([51], Eq. 15). This method is a special case of the following binomial method in order to ensure bitwise regression.
\[ \omega = ((\omega_{vis})^2 + (\omega_{log})^2)^{1/2} \]
The omega estimation at \(y^+\) is blended between the viscous and intertial sublayer estimations by using a binomial function ([51], Eqs. 15-16).
\[ \omega = ((\omega_{vis})^n + (\omega_{log})^n)^{1/n} \]
where
| \( n \) | = | Binomial blending exponent |
The omega estimation at \(y^+\) is blended between the viscous and intertial sublayer estimations by using an exponential function ([62], Eq. 32).
\[ \omega = \omega_{vis} \exp[-\Gamma] +\omega_{log} \exp[-1/\Gamma] \]
where ([62], Eq. 31)
| \( \Gamma \) | = | Blending expression |
| \( \Gamma \) | = | \(0.01 (y^+)^4 / (1.0 + 5.0 y^+)\) |
The omega estimation at \(y^+\) is blended between the viscous and intertial sublayer estimations by using a tanh function ([33], Eqs. 33-34).
\[ \omega = \phi \omega_1 + (1 - \phi) \omega_2 \]
with
\[ \phi = tanh \left( \left(\frac{y^+}{10}\right)^4 \right) \]
\[ \omega_1 = \omega_{vis} + \omega_{log} \]
\[ \omega_2 = \left( (\omega_{vis})^{1.2} + (\omega_{log})^{1.2} \right)^{1/1.2} \]
<patchName>
type omegaWallFunction;
beta1 0.075;
blending binomial2;
n 2.0;
| type | Type name: omegaWallFunction | word | yes | - |
| beta1 | Model coefficient | scalar | no | 0.075 |
| blending | Viscous/inertial sublayer blending method | word | no | stepwise |
| n | Binomial blending exponent | scalar | no | 2.0 |
fixedValueFvPatchFieldnutWallFunctionFvPatchScalarFieldOptions for the blending entry:
Cmu, kappa, and E are obtained from the specified nutWallFunction in order to ensure that each patch possesses the same set of values for these coefficients.binomial2 and binomial blending methods exist at the same time is to ensure the bitwise regression with the previous versions since binomial2 and binomial with n=2 will yield slightly different output due to the miniscule differences in the implementation of the basic functions (i.e. pow, sqrt, sqr).Tutorial
Source code
