The LambVector function object computes 'Lamb vector' [m/s2] [84] (p. 77) which is the cross product of a velocity vector [m/s] and vorticity vector [1/s].
LambVector is defined as follows:
\[ \mathbf{l} = \vec{\omega} \times \u \]
where \(\vec{\omega}(\mathbf{x},t) \equiv \vec{\omega}\) is the vorticity vector, and \(\u (\mathbf{x}, t) \equiv \u\) the velocity vector.
The motivation of LambVector function object is the literature-reported quantitative connection between the Lamb vector (divergence) and the spatially localised instantaneous fluid motions, e.g. high- and low-momentum fluid parcels, which possess considerable level of capacity to affect the rate of change of momentum, and to generate forces such as drag.
| input | volVectorField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the LambVector function object by using functions sub-dictionary in system/controlDict file:
LambVector1
type LambVector;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: LambVector | word | yes | - |
An example of the usage involving the divergence computation of the LambVector can be seen below:
In controlDict.functions:
LambVector1
type LambVector;
field U;
div1
type div;
field LambVector;
fieldAverage1
type fieldAverage;
writeControl writeTime;
fields
LambVector
mean on;
prime2Mean off;
base time;
div(LambVector)
mean on;
prime2Mean off;
base time;
Please note that if default divScheme is none, in fvSchemes.divSchemes, a numerical scheme should be chosen for related quantities, e.g. div(LambVector) as follows:
div(LambVector) Gauss linear;
channel395DFSEM tutorial: $FOAM_TUTORIALS/incompressible/pimpleFoam/LES/channel395DFSEMSource code:
Related:
