The vorticity function object computes the vorticity, the curl of the velocity.
\[ \vec \Omega = \nabla \times \u \]
where
| \( \vec \Omega \) | = | Vorticity vector [1/s] |
| \( \u \) | = | Velocity [m/s] |
| input | volVectorField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | volVectorField | $FOAM_CASE/<time>/<outField> |
Example of the vorticity function object by using functions sub-dictionary in system/controlDict file:
vorticity1
type vorticity;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: vorticity | word | yes | - |
postProcess -func vorticity
channel395DFSEM tutorial: $FOAM_TUTORIALS/incompressible/pimpleFoam/LES/channel395DFSEMSource code:
Related:
