The Q function object computes the second invariant of the velocity gradient tensor [ \(s^{-2}\)]:
\[ Q = \frac{1}{2}\left[\left(\mathrm{tr} \left(\grad \u\right)\right)^2 - \mathrm{tr} \left(\grad \u \dprod \grad \u\right)\right] \]
Q iso-surfaces are good indicators of turbulent flow structures.
| input | volVectorField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the Q function object by using functions sub-dictionary in system/controlDict file:
Q1
type Q;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: Q | word | yes | - |
postProcess -func Q
The Q field is stored on the mesh database, using the default name
Q
If the field entry is set to a value other than U, the default name becomes
Q(<field>)
This can be overridden using the result entry.
channel395DFSEM tutorial: $FOAM_TUTORIALS/incompressible/pimpleFoam/LES/channel395DFSEMSource code:
Related:
