The valueAverage function object computes the ensemble- or time-based singular-value average values, with optional windowing, from the output of function objects that generate non-field type values (e.g. Cd of forceCoeffs or momentum_x in momentum function objects).
| input | - | - |
| output field | - | - |
Example of the valueAverage function object by using functions sub-dictionary in system/controlDict file:
valueAverage1
type valueAverage;
functionObject <FO>; // forceCoeffs1;
fields (<field1> ... <fieldN>); // (Cm Cd Cl);
resetOnRestart false;
window 0.5;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: valueAverage | word | yes | - |
| functionObject | Name of function object to retrieve data | word | yes | - |
| fields | Names of operand fields | wordList | yes | - |
| resetOnRestart | Reset the averaging on restart | bool | no | false |
| window | Averaging window | scalar | no | VGREAT |
Text reporting:
Cd, retrieved from a forceCoeffs function object: CdMean: 0.3
