The forceCoeffs function object generates aerodynamic force and moment coefficient data for surfaces and porous regions, with optional:
Basic operation of the forceCoeffs function object comprises:
forceCoeffs1
type forceCoeffs;
libs ("libforces.so");
patches (<list of patch names>);
For more complete control, the full set of input entries includes:
forceCoeffs1
// Mandatory entries
type forceCoeffs;
// Optional entries
// Field names
p p;
U U;
rho rho;
// Reference pressure [Pa]
pRef 0;
// Include porosity effects?
porosity no;
// Store and write volume field representations of forces and moments
writeFields yes;
// Centre of rotation for moment calculations
CofR (0 0 0);
// Lift direction
liftDir (0 0 1);
// Drag direction
dragDir (1 0 0);
// Pitch axis
pitchAxis (0 1 0);
// Freestream velocity magnitude [m/s]
magUInf 30;
// Reference length [m]
lRef 1;
// Reference area [m2]
Aref 1.75;
// Spatial data binning
// - extents given by the bounds of the input geometry
binData
nBin 20;
direction (1 0 0);
cumulative yes;
Default behaviour assumes that the case is compressible. For incompressible cases, i.e. solved using the kinematic pressure:
\[ p_k = \frac{p}{\rho} \qquad [\mathrm{m}^2 \mathrm{s}^{-2}]\]
the rho entry can be used to set the freestream density:
rho rhoInf; rhoInf 100000;
Fields
forceCoeffmomentCoeffStoring of integrated values for further post-processing:
CmCdClCl(f)Cl(r)Related:
Example usage:
nacaAirfoil tutorial: $FOAM_TUTORIALS/compressible/sonicFoam/RAS/nacaAirfoil| Would you like to suggest an improvement to this page? | Create an issue |
