The forces function object generates aerodynamic force and moment data for surfaces and porous regions, with optional
Forces comprise normal pressure
\[ \vec{F}_p = \sum_i \rho_i \vec{s}_{f,i} \left(p_i - p_{ref}\right) \]
and tangential viscous contributions:
\[ \vec{F}_v = \sum_i s_{f,i} \dprod \left(\mu \tensor{R_{\mathrm{dev}}} \right) \]
Where \( \rho \) is the density, \( \vec{s}_{f,i} \) the face area vector, \( p \) the pressure \( \mu \) the dynamic viscosity and \( \tensor{R_{\mathrm{dev}}} \) the deviatoric stress tensor.
Basic operation of the forces function object comprises:
forces1
type forces;
libs ("libforces.so");
patches (<list of patch names>);
For more complete control, the full set of input entries includes:
forces1
// Mandatory entries
type forces;
// Optional entries
// Field names
p p;
U U;
rho rho;
// Reference pressure [Pa]
pRef 0;
// Include porosity effects?
porosity no;
// Store and write volume field representations of forces and moments
writeFields yes;
// Centre of rotation for moment calculations
CofR (0 0 0);
// Spatial data binning
// - extents given by the bounds of the input geometry
binData
nBin 20;
direction (1 0 0);
cumulative yes;
Default behaviour assumes that the case is compressible. For incompressible cases, i.e. solved using the kinematic pressure the rho entry can be used to set the free stream density:
rho rhoInf; rhoInf 100000;
Text reporting:
Sum of forces
Total : xxx
Pressure : xxx
Viscous : xxx
Porous : xxx
Sum of moments
Total : xxx
Pressure : xxx
Viscous : xxx
Porous : xxx
Optional storing and writing of force and moment fields:
forcesmomentsStoring of integrated values for further post-processing:
normalForcetangentialForceporousForcenormalMomenttangentialMomentporousMomentRelated:
Example usage:
propeller tutorial: $FOAM_TUTORIALS/incompressible/pimpleFoam/RAS/propeller| Would you like to suggest an improvement to this page? | Create an issue |
