OpenFOAM solver applications typically include core functionality such as turbulence modelling, heat transfer, and buoyancy effects.
Further flexibility is offered via fvOptions—a collection of run-time selectable finite volume options to manipulate systems of equations by adding sources/sinks, imposing constraints and applying corrections.
These are specified in the fvOptions file located in the $FOAM_CASE/system or $FOAM_CASE/constant directories.
The majority of options are applied to collections of mesh cells. These can be selected according to the entry selectionMode, e.g.
selectionMode all;
Valid selectionMode entries include:
all: all cellscellZone: cells defined by a cell zone. This requires an additional entry to specify the name of the cell zone, e.g. selectionMode cellZone; cellZone myCellZone;
where myCellZone is the name of the cell zone
cellSet: cells defined by a cell set. This requires an additional entry to specify the name of the cell set, e.g. selectionMode cellSet; cellSet myCellSet;
where myCellSet is the name of the cell set.
points: a list of points. This requires an additional entry to list the points, e.g. selectionMode points; points ((0 0 0) (1 1 1) (2 2 2));
Copyright © 2016-2018 OpenCFD Ltd.
