Overview
OpenFOAM includes a wide range of solution and scheme controls, specified via dictionary files in the case system sub-directory. These are described by:
- Numerical schemes: The treatment of each term in the system of equations is specified in the fvSchemes dictionary. This enables fine-grain control of e.g. temporal, gradient, divergence and interpolation schemes.
- Linear equation solvers Solution methods: Case solution parameters are specified in the fvSolution dictionary. These include choice of linear equation solver per field variable, algorithm controls e.g. number of inner and outer iterations and under-relaxation.
- Finite volume options: Additional run-time selectable physical modelling and general finite terms are prescribed in the fvOptions dictionary, targeting e.g. acoustics, heat transfer, momentum sources, multi-region coupling, linearised sources/sinks and many more
Topics
Copyright © 2016 OpenCFD Ltd.
Licensed under the Creative Commons License BY-NC-ND
