Flag to run/skip castellation stage
castellatedMesh yes; // no
Flag to run/skip snapping stage
snap yes; // no
Flag to run/skip layer addition stage
addLayers yes; // no
Single region surfaces get patch names according to the surface only. Multi-region surfaces get patch name surface "_ "region. Default is true
singleRegionName yes; // no
Avoid patch-face merging. Allows mesh to be used for refinement/unrefinement. Default is true
mergePatchFaces yes; // no
Preserve all generated patches. Default is to remove zero-sized patches (false).
keepPatches no; // yes
Merge tolerance. Is fraction of overall bounding box of initial mesh. Note: the write tolerance needs to be higher than this.
Debug levels to write intermediate mesh data. Use debugFlags instead for better control
Example
debug 1;
Provides fine-grain control over the debug output, including:
mesh: write intermediate meshesintersections: write current mesh intersections as .obj filesfeatureSeeds: write information about explicit feature edge refinementattraction: write attraction as .obj fileslayerInfo: write information about layersExample
debugFlags
featureSeeds
attraction
Provides fine-grain control over the write output, including:
mesh: write all mesh informationnoRefinement: write mesh without refinement information (level0Edges, surfaceIndex)scalarLevels: write volScalarField with cellLevel for post-processinglayerSets: write cellSets, faceSets of faces in layerlayerFields: write a volScalarField for layer coverageExample
writeFlags
scalarLevels
layerSets
layerFields // write volScalarField for layer coverage
Copyright © 2018 OpenCFD Ltd.
