An example use of the triSurfaceMesh:
sphere.stl // name of the geometrical entity
type triSurfaceMesh;
// Per region the patch name. If not provided will be <surface>_<region>.
// Note: this name cannot be used to identity this region in any
// other part of this dictionary; it is only a name
// for the combination of surface+region (which is only used
// when creating patches)
regions
secondSolid
name mySecondPatch;
Optional entries include:
// Tolerance to use for intersection tests tolerance 1e-5; // Scale factor to apply to the points scale 0.001; // Name to use to refer to this surface name surface1;
See also
Copyright © 2019 OpenCFD Ltd.
