The scheme is specified using:
divSchemes
default none;
div(phi,U) Gauss filteredLinear2 <k> <l>;
Where the coefficients
k: Scales the rate at which the correction is appliedl: Maximum allowed overshoot/undershoot relative to the difference across the face.Source code
