Taking the Laplacian of a property \(\phi\) is represented using the notation:
\[ \laplacian \phi = \frac{\partial^2}{\partial x_1^2} \phi + \frac{\partial^2}{\partial x_2^2} \phi + \frac{\partial^2}{\partial x_3^2} \phi \]
or as a combination of divergence and gradient operators
\[ \div \left( \Gamma \grad \phi \right) \]
where \( \Gamma \) is a diffusion coefficient.
Laplacian schemes are specified in the fvSchemes file under the laplacianSchemes sub-dictionary using the syntax:
All options are based on the application of Gauss theorem, requiring an interpolation scheme to transform coefficients from cell values to the faces, and a surface-normal gradient scheme.
Copyright © 2016 OpenCFD Ltd.
