The Van Driest damping function is given by:
\[ D = 1 - \exp^\frac{-y^+}{A^+} \]
The final length scale is given by:
\[ \Delta = \min \left( \frac{\kappa y}{C_s} D , \Delta_g \right) \]
where \( \Delta_g \) is a geometric-based delta function such as the cube-root volume delta.
The model is specified using:
delta vanDriest;
vanDriestCoeffs
delta <geometricDelta>;
// Optional entries
kappa 0.41;
Aplus 26;
Cdelta 0.158;
calcInterval 1;
The model requires the near wall distance \(y\) which can be costly to compute for moving mesh cases. Here, the optional calcInterval entry can be used to reduce the update frequency of the wall distance calculation at the expense of increased modelling errors.
Copyright © 2018 OpenCFD Ltd.
