The turbulence kinetic energy equation is given by:
\[ \Ddt{\rho k} = \div \left( \rho D_k \grad k \right) + \rho G - \frac{2}{3} \rho k \div \u - \frac{C_e \rho k^{1.5}}{\Delta} + S_k \]
The \( C_e \) and \( C_k \) coefficients are derived from local flow properties.
None
The model is specified using:
LES
turbulence on;
LESModel dynamicKEqn;
Inlet
Outlet
Walls
References:
