The turbulence specific dissipation rate equation is given by:
\[ \Ddt{\rho \omega} = \div \left( \rho D_\omega \grad \omega \right) + \frac{\rho \gamma G}{\nu} - \frac{2}{3} \rho \gamma \omega \left( \div \u \right) - \rho \beta \omega^2 - \rho \left(F_1 - 1\right) CD_{k\omega} + S_\omega, \]
and the turbulence kinetic energy by:
\[ \Ddt{\rho k} = \div \left( \rho D_k \grad k \right) + \rho G - \frac{2}{3} \rho k \left( \div \u \right) - \rho \beta^{*} \omega k + S_k. \]
The turbulence viscosity is obtained using:
\[ \nu_t = a_1 \frac{k}{\max (a_1 \omega_, b_1 F_{23} \tensor{S})} \]
| \(\alpha_{k1}\) | \(\alpha_{k2}\) | \(\alpha_{\omega 1}\) | \(\alpha_{\omega 2}\) | \(\beta_1\) | \(\beta_2\) | \(\gamma_1\) | \(\gamma_2\) |
| 0.85 | 1.0 | 0.5 | 0.856 | 0.075 | 0.0828 | 5/9 | 0.44 |
| \(\beta^{*}\) | \(a_1\) | \(b_1\) | \(c_1\) |
| 0.09 | 0.31 | 1.0 | 10.0 |
For isotropic turbulence, the turbulence kinetic energy can be estimated by:
\[ k = \frac{3}{2} \left(I |\u_{ref}|\right)^{2} \]
where \( I \) is the intensity, and \( \u_{ref} \) a reference velocity. The turbulence specific dissipation rate follows as:
\[ \omega = \frac{k^{0.5}}{C_{\mu}^{0.25} L} \]
where \( C_{\mu} \) is a constant equal to 0.09, and \( L \) a reference length scale.
The model is specified using:
RAS
turbulence on;
RASModel kOmegaSST;
Inlet
Outlet
Walls
References:
See also:
