The turbulence kinetic energy equation is given by:
\[ \Ddt{k} = \div \left( D_k \grad k \right) + G - \epsilon \]
and the turbulence dissipation rate equation by:
\[ \Ddt{\epsilon} = \div \left( D_\epsilon \grad \epsilon \right) + C_{\epsilon 1} G \epsilon/k - C_{\epsilon 2} f_2 \epsilon^2/k + E \]
The model is specified using:
RAS
turbulence on;
RASModel LienLeschziner;
References:
