\[ y(x) = \begin{cases} 0.05 [\sin(\pi \frac{x}{0.9}-\frac{\pi}{3})]^4, & 0.3 \le x \le 1.2, \\ 0 , & 0 \le x \lt 0.3 \, \text{and} \, 1.2 \lt x \le 1.5. \end{cases} \]
blockMeshDict using a codeStream
\[ Ma = \sqrt{\gamma R T} \]
where \( \gamma \) is the ratio of specific heats, \( R \) the gas constant and \( T \) the temperarture. Using values for air at 300K, the inflow velocity is given as:\[ U = 0.2 Ma = 0.2 \sqrt{1.4 \times 287 \times 300} = 69.44 m/s \]
\[ \nu_\infty = \frac{|\u| L}{Re} = \frac{69.44 \times 1}{3 \times 10^6} = 2.31 \times 10^{-5} m^2/s \]
Velocity: U
| Patch | condition | value |
| Inlet | fixedValue | 69.44 m/s in x |
| Outlet | zeroGradient | |
| Bump | noSlip | |
| Walls | symmetryPlane |
Pressure: p
| Inlet | zeroGradient | |
| Outlet | fixedValue | 0 Pa (static) |
| Bump | zeroGradient | |
Turbulence viscosity: nut
| Inlet | calculated | |
| Outlet | calculated | |
| Bump | nutUSpaldingWallFunction | |
Modified turbulence viscosity: nuTilda
| Inlet | fixedValue | based on \( 3 \nu_\infty\) |
| Bump | fixedValue | 0 |
The NASA Turbulence Modelling Resource employs a code comparison to show that the FUN3D and CFL3D codes produce equivalent results for this case. OpenFOAM and CFL3D results are presented in the following series of images, showing that OpenFOAM results compare very favourably.
Normalised turbulence viscosity | |
Skin friction |
Pressure coefficient |
Copyright © 2018 OpenCFD Ltd.
