A precursor boundaryFoam calculation is used to set the inlet flow conditions onto which turbulent content is superimposed using the turbulentDFSEMInlet velocity condition.
Velocity: U
| Patch | condition | value |
| Inlet | turbulentDFSEMInlet | |
| Outlet | zeroGradient | |
| Walls | noSlip |
Pressure: p
| Inlet | zeroGradient | |
| Outlet | fixedValue | 0 Pa (static) |
| Walls | zeroGradient |
Turbulence viscosity: nut
| Inlet | calculated | |
| Outlet | calculated | |
| Walls | nutUSpaldingWallFunction |
Modified viscosity: nuTilda
| Inlet | mappedFixedValue | |
The following images show examples of the instantaneous- and mean-velocity predictions
Velocity |
Velocity |
Mean velocity |
Mean velocity |
Profiles at a series of x/h positions are presented in the following images, where the predictions are compared against the experimental data of Martinuzzi and Tropea [49]
x/h = -1 |
x/h = -0.5 |
x/h = 1 |
x/h = 1.5 |
x/h = 2.5 |
x/h = 4 |
Copyright © 2018 OpenCFD Ltd.
