OpenFOAM® v2.0.0: Post-Processing
Function Objects
OpenFOAM can carry out post-processing (and run-time control) automatically while the simulation is running using function objects. In v2.0.0, the range of available functionality has been extended to include the following:
- abortCalculation - Watches for presence of the named file in the case directory and aborts the calculation if it is present.
- coded - See Run-time Control: Code Compilation
- fieldValue - faceSource extended to integrals (e.g. mass flux) over any sampleSurface, e.g. triSurfaceMesh.
- nearWallFields - generates a volField with boundary values from interpolated internal field, at a given distance from the wall.
- partialWrite - allows registered objects, e.g. fields, to be written at different times (frequencies).
- streamLine - generates streamlines in one of the sample formats.
- timeActivatedFileUpdate - modifies case settings at specified times in a simulation.
- writeRegisteredObject - writes registered objects, e.g. fields that are not scheduled to be written in the application, i.e. created with NO_WRITE.
Below is an example of an image the elements of which are created from data files generated by function objects, rather than by post-processing the actual OpenFOAM solution data itself. The image includes streamlines, a cutting plane, coloured by velocity, and the motor bike surface, coloured by pressure.
- Source code
- fieldFunctionObjects library -
$FOAM_SRC/postProcessing/functionObjects/field
IOFunctionObjects library - $FOAM_SRC/postProcessing/functionObjects/IO
jobControl library - $FOAM_SRC/postProcessing/functionObjects/jobControl
utilityFunctionObjects library - $FOAM_SRC/postProcessing/functionObjects/utilities - Examples
- Example controlDict files in the source code, listed with the
command:
find $FOAM_SRC/postProcessing -name controlDict
Examples in the tutorials, listed with the command:
find $FOAM_TUTORIALS -name controlDict | xargs grep -l functions
Other Changes to Post-Processing
Other new features and improvements in post-processing include the following.
- Paraview and the foamToVTK utility now include full support for polyhedral cells.
- The foamToEnsight utility supports parallel continuous data so that isosurfaces, etc., are continuous across processor boundaries, and includes a new -nodeValues option to generate and output nodal field data.
- A new singleCellMesh utility converts a mesh and fields to a single cell mesh, so that only boundary data is preserved; useful for post-processing large cases.
- A steadyParticleTracks utility generates VTK tracks from data for a particle cloud.
- The sampling library includes a new ensight output format for surface sampling and a new patchInternalField sampling surface that operates like patch samples the internal field, instead of the boundary (patch) field.
