nutUBlendedWallFunction boundary condition provides a wall constraint on the turbulent viscosity, i.e. nut, based on velocity, i.e. U using a binomial-function wall-function blending method between the viscous and inertial sublayer predictions of nut for low- and high-Reynolds number turbulence models.nutUBlendedWallFunction condition inherits some of the traits of the nutWallFunction boundary condition.Required fields:
nut | Turbulent viscosity [m2/s]
The model expressions ([52]):
\[ \nu_t = \max(0, \frac{u_{\tau^*}^2}{|\grad{\u}| + \zeta} -\nu_w) \]
with
\[ u_{\tau^*} = \left( u_{\tau_{vis}}^n + u_{\tau_{log}}^n \right)^{1/n} \]
\[ u_{\tau_{vis}} = \frac{u_p}{y^+} \]
\[ u_{\tau_{log}} = \kappa \frac{u_p}{\ln(E y^+)} \]
where
| \( \nu_t \) | = | Turbulent viscosity [m2/s] |
| \( u_{\tau^*} \) | = | Friction velocity estimation obtained by iterative means [m/s] |
| \( u_{\tau_{vis}} \) | = | \(u_\tau\) computed by the viscous sublayer assumptions [m2/s] |
| \( u_{\tau_{log}} \) | = | \(u_\tau\) computed by the inertial sublayer assumptions [m2/s] |
| \( y^+ \) | = | Estimated wall-normal height of the cell centre in wall units |
| \( E \) | = | Wall roughness parameter [-] |
| \( u_p \) | = | Magnitude of near wall velocity [m/s] |
| \( \u \) | = | Velocity [m/s] |
| \( n \) | = | Blending exponent [-] |
| \( \zeta \) | = | Small value to prevent floating point exceptions |
<patchName>
type nutUBlendedWallFunction;
n 4.0;
| type | Type name: nutUBlendedWallFunction | word | yes | - |
| n | Blending factor | scalar | no | 4.0 |
blending option binomial or with the deprecated blended flag set to on.correctNut() (called through turbulence->validate) returns a slightly different value every time it is called. See nutUSpaldingWallFunction.Tutorial
Source code
