The surfaceFieldValue function object provides options to manipulate surface field data into derived forms, e.g. to report summations, averages and extrema; to calculate the volumetric or mass flux across a patch.
Base operations:
none : no operationmin : minimummax : maximumsum : summationsumMag : sum of magnitudessumDirection :sumDirectionBalance :average : averageareaAverage : area averageareaIntegrate : area integralCoV : Coefficient of VariationareaNormalAverage : area-normal averageareaNormalIntegrate : area-normal integraluniformity : uniformity indexWeighted operations:
weightedSumweightedAverageweightedAreaAverageweightedAreaIntegrateweightedUniformityAbsolute weighted operations:
absWeightedSumabsWeightedAverageabsWeightedAreaAverageabsWeightedAreaIntegrateabsWeightedUniformityExample of the surfaceFieldValue function object by using functions sub-dictionary in system/controlDict file:
surfaceFieldValue1
type surfaceFieldValue;
operation <operationType>;
regionType patch;
name <patch>;
postOperation none;
weightField alpha1;
scaleFactor 1.0;
writeArea false;
surfaceFormat none;
writeFields false;
scalingFactor 1.0;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: surfaceFieldValue | word | yes | - |
| fields | Names of operand fields | wordList | yes | - |
| regionType | Face regionType: see below | word | yes | - |
| name | Name for regionType | word | yes | - |
| operation | Operation type: see below | word | yes | - |
| postOperation | Post-operation type: see below | word | no | none |
| weightField | Name of field to apply weighting | word | no | none |
| scaleFactor | Output value scaling factor | scalar | no | 1.0 |
| writeArea | Write the surface area | bool | no | false |
| surfaceFormat | Output value format | word | conditional on writeFields | none |
Options for the regionType entry:
faceZone | The `name` entry to specify the faceZone patch | The `name` entry to specify the patch functionObjectSurface | The `name` entry to specify a polySurface sampledSurface | A `sampledSurfaceDict` sub-dictionary and `name`
Options for the operation entry:
none | no operation min | minimum max | maximum sum | sum sumMag | sum of component magnitudes sumDirection | sum values that are positive in given direction sumDirectionBalance | sum of balance of values in given direction average | ensemble average areaAverage | area-weighted average areaIntegrate | area integral CoV | coefficient of variation: standard deviation/mean areaNormalAverage | area-weighted average in face normal direction areaNormalIntegrate | area-weighted integral in face normal directon uniformity | uniformity index weightedSum | weighted sum weightedAverage | weighted average weightedAreaAverage | weighted area average weightedAreaIntegrate | weighted area integral weightedUniformity | weighted uniformity index absWeightedSum | sum using absolute weighting absWeightedAverage | average using absolute weighting absWeightedAreaAverage | area average using absolute weighting absWeightedAreaIntegrate | area integral using absolute weighting absWeightedUniformity | uniformity index using absolute weighting
Options for the postOperation entry:
none | No additional operation after calculation mag | Component-wise `mag()` after normal operation sqrt | Component-wise `sqrt()` after normal operation
areaNormalAverage and areaNormalIntegrate operations are written as the first component of a field with the same rank as the input field.faceZone can only consist of boundary faces.functionObjectSurface:subRegion should not be used to select surfaces. Instead specify the regionType functionObjectSurface and provide the name.sampledSurface:interpolate=true they use interpolationCellPoint otherwise they use cell valuessampledSurface is logically only in one cell so interpolation will be wrong when triangles are larger than cells. This can only happen for sampling on a triSurfaceMeshUniformity:
\[ UI(\phi) = 1 - \frac{1}{2 \overline{\phi} A} \int{\left| W \phi \cdot \hat{n} - \bar{W} \bar{\phi}\right| d\vec{A}} \,,\; \bar{\phi} = \frac{\int{W \phi \cdot d\vec{A}}}{\int{W \cdot d\vec{A}}} \]
A velocity uniformity index is calculated with no weighting (W=1) and \(\phi = \u\).
A scalar concentration uniformity index is calculated with either \(\rho \u\) or \(\u\) for weighting and \(\phi = conc\).
Data is written to file
$FOAM_CASE/postProcessing/<function object>/<start time>/surfaceFieldValue.dat
An example of a typical output is given below:
# Area : 1.2500000000e-03 # Scale factor : 1.0000000000e+00 # Time weightedAverage(H2O) weightedAverage(T) 0.01 9.9999967766e-03 4.7103661930e+02 0.02 9.9999999984e-03 4.7138303908e+02 0.03 1.0000000000e-02 4.7183514514e+02 0.04 1.0000000000e-02 4.7224152840e+02 0.05 1.0000000032e-02 4.7252916359e+02 0.06 1.0000076331e-02 4.7287719550e+02 0.07 1.0013972934e-02 4.7510153455e+02
verticalChannel tutorial: $FOAM_TUTORIALS/lagrangian/reactingParcelFoam/verticalChannelSource code:
Related:
