The volFieldValue function object provides options to manipulate volume field data into derived forms, e.g. to report summations, averages and extrema.
Operations:
none : no operationsum : summationsumMag : sum of magnitudeaverage: averageweightedAverage: weighted averagevolAverage: volume averageweightedVolAverage: weighted volume averagevolIntegrate: volume integralmin: minimummax: maximumCoV: coefficient of variationExample of the volFieldValue function object by using functions sub-dictionary in system/controlDict file:
volFieldValue1
type volFieldValue;
operation <operationType>;
regionType <volRegion>;
postOperation none;
weightField alpha1;
writeFields false;
scalingFactor 1.0;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: surfaceFieldValue | word | yes | - |
| fields | Names of operand fields | wordList | yes | - |
| regionType | Face regionType: see below | word | yes | - |
| name | Name for regionType | word | yes | - |
| operation | Operation type: see below | word | yes | - |
| postOperation | Post-operation type: see below | word | no | none |
| weightField | Name of field to apply weighting | word | no | none |
Options for the regionType entry:
cellZone | requires a 'name' entry to specify the cellZone all | all cells
Options for the operation entry:
none | No operation min | Minimum max | Maximum sum | Sum sumMag | Sum of component magnitudes average | Ensemble average volAverage | Volume weighted average volIntegrate | Volume integral CoV | Coefficient of variation: standard deviation/mean weightedSum | Weighted sum weightedAverage | Weighted average weightedVolAverage | Weighted volume average weightedVolIntegrate | Weighted volume integral
Options for the postOperation entry:
none | No additional operation after calculation mag | Component-wise \c mag() after normal operation sqrt | Component-wise \c sqrt() after normal operation
Related:
