This constraint will fix the temperature in the energy equation in the mesh region specified, regardless of incoming flow temperature or local flow behaviour.
Downstream of the constraint the temperature field will continue to develop normally. Please note this will only affect the temperature field. Other thermodynamic fields, e.g. density, may still show sensitivity to the local pressure (if applicable). Note that this constraint will cause a non-conservation of energy. No information will be added to the log file other than the identification of the constraint at the start of the simulation.
fixedTemperature
type fixedTemperatureConstraint;
active yes;
selectionMode cellZone;
cellZone porosity;
mode uniform; // uniform or lookup
// For uniform option
temperature constant 500; // fixed temperature with time [K]
// For lookup option
// T <Tname>; // optional temperature field name
Tutorials
Source code
Copyright © 2018 OpenCFD Ltd.
