Enables users to set field values in the domain, irrespective of the local flow conditions.
Downstream fields outside the region constrained will continue developing normally.
The constraint is available for all primitive field types, i.e. scalar, vector, sphericalTensor, symTensor and tensor, where the type entry is set as
type <type>FixedValueConstraint
For example, the scalar variant can be applied to the turbulence k and epsilon fields using:
fixedValue
type scalarFixedValueConstraint;
active yes;
selectionMode cellZone; //cellZone or all
cellZone porosity;
fieldValues
k 1;
epsilon 150; // any field values can be modified, including scalars.
Tutorials
Source code
Copyright © 2018 OpenCFD Ltd.
