actuationDiskSource applies sources on velocity, i.e. U, to enable actuator disk models for aero/hydro thrust loading of rotary disks (e.g. propellers, horizontal-axis wind/tidal turbines, or helicopter rotors) on surrounding flow field in terms of energy conversion processes.actuationDiskSource is applied on the volume cells (not on faces). This nuance might be important since theoretical actuator disks possess zero-thickness.actuationDiskSource inherits the traits of the fvOption, and cellSetOption.Corrections applied to:
U | Velocity [m/s]
Required fields:
U | Velocity [m/s]
The actuationDiskSource possesses two options for force computations:
Froude | Froude's one-dimensional ideal actuator disk method variableScaling | Variable-scaling actuator disk method
The model expressions for Froude method ([8], Eq. 3.9):
\[ T = 2 \rho_{ref} A | \u_m \cdot \vec{n} |^2 a (1-a) \]
with
\[ a = 1 - \frac{C_p}{C_T} \]
where
| \( T \) | = | Thrust magnitude [N] |
| \( \rho_{ref} \) | = | Monitored incoming fluid density [kg/m3] |
| \( A \) | = | Actuator disk planar surface area [m2] |
| \( \u_m \) | = | Incoming velocity spatial-averaged on monitored region [m/s] |
| \( \vec{n} \) | = | Surface-normal vector of the actuator disk pointing upstream [-] |
| \( a \) | = | Axial induction factor [-] |
| \( C_p \) | = | Power coefficient [-] |
| \( C_T \) | = | Thrust coefficient [-] |
The model expressions for variableScaling method (([86], Eqs. 5-6), ([87])):
\[ T = 0.5 \rho_{ref} A | \u_o \cdot \vec{n} |^2 C_T^* \]
with
\[ C_T^* = C_T \left( \frac{ | \u_m | }{ | \u_o | } \right)^2 \]
where
| \( \u_o \) | = | Incoming velocity spatial-averaged on actuator disk [m/s] |
| \( C_T^* \) | = | Calibrated thrust coefficient [-] |
| input | - | - |
| output file | dat | $POST=$FOAM_CASE/postProcessing/<FvO>/<time>/<file> |
actuationDiskSource1
type actuationDiskSource;
selectionMode <mode>; // e.g. cellSet as shown below
cellSet <cellSetName>;
diskArea 40.0;
diskDir (1 0 0);
Cp <Function1>;
Ct <Function1>;
// Conditional optional entries (unmodifiable)
monitorMethod <points|cellSet>;
monitorCoeffs
// Option-1
points
(p1x p1y p1z)
(p2x p2y p2z)
// Option-2
cellSet <monitorCellSet>;
variant <forceMethod>;
sink true;
writeFileStart 0;
writeFileEnd 100;
| type | Type name: actuationDiskSource | word | yes | - |
| diskArea | Actuator disk planar surface area | scalar | yes | - |
| diskDir | Surface-normal vector of the actuator disk pointing upstream | vector | yes | - |
| Cp | Power coefficient | Function1 | yes | - |
| Ct | Thrust coefficient | Function1 | yes | - |
| monitorMethod | Type of incoming velocity monitoring method - see below | word | no | points |
| variant | Type of the force computation method - see below | word | no | Froude |
| sink | Flag for body forces to act as a source (true) or a sink (false) | bool | no | true |
| writeFileStart | Start time for file output | scalar | no | 0 |
| writeFileEnd | End time for file output | scalar | no | VGREAT |
Options for the monitorMethod entry:
points | Monitor incoming velocity field at a given set of points cellSet | Monitor incoming velocity field at a given cellSet
Options for the variant entry:
Sample result
