atmAmbientTurbSource applies sources on k and either epsilon or omega to prevent them droping below a specified ambient value for atmospheric boundary layer modelling.atmAmbientTurbSource can be applied on epsilon or omega based RAS turbulence models.atmAmbientTurbSource inherits the traits of the fvOption, and cellSetOption.Corrections applied to:
k | Turbulent kinetic energy [m2/s2]
Corrections applied to either of the below, if exist:
epsilon | Turbulent kinetic energy dissipation rate [m2/s3] omega | Specific dissipation rate [1/s]
Required fields:
k | Turbulent kinetic energy [m2/s2] epsilon/omega | Dissipation rate OR Specific dissipation rate [m2/s3]/[1/s]
The model expression for epsilon (Heuristically derived from ([64], Eq. 4, rhs-term:5)):
\[ S_p = \alpha \rho C_2 \frac{\epsilon_{amb}^2}{k_{amb} \epsilon_o} \epsilon \]
The model expression for omega ([64], Eq. 4, rhs-term:5):
\[ S_p = \alpha \rho C_\mu \beta \frac{\omega^2_{amb}}{\omega_o} \omega \]
The model expression for k when epsilon is available (Heuristically derived from ([64], Eq. 3, rhs-term:4)):
\[ S_p = \alpha \rho \frac{\epsilon_{amb}}{k_o} k \]
The model expression for k when omega is available ([64], Eq. 3, rhs-term:4):
\[ S_p = \alpha \rho C_\mu \frac{\omega_{amb} k_{amb}}{k_o} k \]
where
| \( S_p \) | = | Source term without boundary conditions |
| \( \epsilon \) | = | Turbulent kinetic energy dissipation rate (Current iteration) [m2/s3] |
| \( \omega \) | = | Specific dissipation rate (Current iteration) [1/s] |
| \( k \) | = | Turbulent kinetic energy (Current iteration) [m2/s2] |
| \( \epsilon_{amb} \) | = | Ambient epsilon value [m2/s3] |
| \( \omega_{amb} \) | = | Ambient omega value [1/s] |
| \( k_{amb} \) | = | Ambient k value [m2/s2] |
| \( \epsilon_o \) | = | Previous-iteration epsilon [m2/s3] |
| \( \omega_o \) | = | Previous-iteration omega [1/s] |
| \( k_o \) | = | Previous-iteration k [m2/s2] |
| \( C_2 \) | = | Model constant [-] |
| \( \beta \) | = | Model constant [-] |
| \( \alpha \) | = | Phase fraction in multiphase computations, otherwise equals to 1 |
| \( \rho \) | = | Fluid density in compressible computations, otherwise equals to 1 |
atmAmbientTurbSource1
type atmAmbientTurbSource;
atmAmbientTurbSourceCoeffs
selectionMode all;
kAmb 0.0;
rho rho;
epsilonAmb 0.0;
omegaAmb 0.0;
| type | Type name: atmAmbientTurbSource | word | yes | - |
| kAmb | Ambient value for k | scalar | yes | - |
| epsilonAmb | Ambient value for epsilon | scalar | no | 0.0 |
| omegaAmb | Ambient value for omega | scalar | no | 0.0 |
cellSetOptionTutorials
Source code
