atmLengthScaleTurbSource applies sources on either epsilon or omega to correct mixing-length scale estimations for atmospheric boundary layer modelling.atmLengthScaleTurbSource can be applied on epsilon or omega based RAS turbulence models.atmLengthScaleTurbSource inherits the traits of the fvOption, and cellSetOption.Corrections applied to either of the below, if exist:
epsilon | Turbulent kinetic energy dissipation rate [m2/s3] omega | Specific dissipation rate [1/s]
Required fields, either of the below:
The model expression for epsilon:
\[ S_p = \alpha \rho C_1^* \frac{G_o}{\nu} C_\mu k_o \]
with ([3], Eq. 16 wherein the exponentiation n is not present. n is an ad-hoc implementation):
\[ C_1^* = (C_2 - C_1) \left( \frac{L}{L_{max}} \right)^n \]
Mixing-length scale estimation ([61], Eq. 10.37 & p. 374):
\[ L = C_\mu^{3/4} \frac{k_o^{3/2}}{\epsilon_o} \]
The model expression for omega:
\[ S_p = \alpha \rho \gamma^* \frac{G_o}{\nu} \]
with ([36], Eq. 3.34):
\[ \gamma^* = \left( \gamma - \beta \right) \left( \frac{L}{L_{max}} \right)^n \]
Mixing-length scale estimation ([36], Eq. 3.20):
\[ L = \frac{\sqrt{k}}{C_\mu^{1/4} \omega_o} \]
where
| \( S_p \) | = | Source term without boundary conditions |
| \( \epsilon_o \) | = | Previous-iteration epsilon [m2/s3] |
| \( \omega_o \) | = | Previous-iteration omega [1/s] |
| \( k_o \) | = | Previous-iteration k [m2/s2] |
| \( G_o \) | = | Previous-iteration k-production contribution [m2/s3] |
| \( C_1 \) | = | Model constant (epsilon-based models) [-] |
| \( C_2 \) | = | Model constant (epsilon-based models) [-] |
| \( C_1^* \) | = | Modified model constant field (epsilon-based models) [-] |
| \( \gamma \) | = | Model constant (omega-based models) [-] |
| \( \beta \) | = | Model constant (omega-based models) [-] |
| \( \gamma^* \) | = | Modified model constant field (omega-based models) [-] |
| \( \nu \) | = | Kinematic viscosity of fluid [m2/s] |
| \( L \) | = | Mixing-length scale [m] |
| \( L_{max} \) | = | Maximum mixing-length scale [m] |
| \( \alpha \) | = | Phase fraction in multiphase computations, otherwise equals to 1 |
| \( \rho \) | = | Fluid density in compressible computations, otherwise equals to 1 |
atmLengthScaleTurbSource1
type atmLengthScaleTurbSource;
atmLengthScaleTurbSourceCoeffs
selectionMode all;
rho rho;
Lmax 41.575;
n 3.0;
| type | Type name: atmLengthScaleTurbSource | word | yes | - |
| Lmax | Maximum mixing-length scale | scalar | no | 41.575 |
| n | Mixing-length scale exponent | scalar | no | 3.0 |
cellSetOptionTutorials
Source code
