atmPlantCanopyTSource applies sources on temperature, i.e. T, to incorporate effects of plant canopy for atmospheric boundary layer modelling.atmPlantCanopyTSource can be applied on any RAS turbulence model.atmPlantCanopyTSource inherits the traits of the fvOption, and cellSetOption.Corrections applied to:
T | Temperature [K]
Required fields:
T | Temperature [K] qPlant | Tree-height based specific heat flux [m2/s3]
The model expression:
\[ f_M += \alpha \rho \frac{q_{plant}}{C_{p_0}} \]
where
| \( f_M \) | = | fvMatrix of the temperature field [K/s] |
| \( q_{plant} \) | = | Tree-height based specific heat flux [m2/s3] |
| \( C_{p_0} \) | = | Specific heat capacity [m2/s2/K] |
| \( \alpha \) | = | Phase fraction in multiphase computations, otherwise equals to 1 |
| \( \rho \) | = | Fluid density in compressible computations, otherwise equals to 1 |
atmPlantCanopyTSource1
type atmPlantCanopyTSource;
atmPlantCanopyTSourceCoeffs
selectionMode all;
rho rho;
Cp0 1005.0;
| type | Type name: atmPlantCanopyTSource | word | yes | - |
| Cp0 | Specific heat capacity [m2/s2/K] | scalar | no | 1005.0 |
cellSetOptionTutorials
Source code
