atmPlantCanopyTurbSource applies sources on either epsilon or omega to incorporate effects of plant canopy for atmospheric boundary layer modelling.atmPlantCanopyTurbSource can be applied on epsilon or omega based RAS turbulence models.atmPlantCanopyTurbSource inherits the traits of the fvOption, and cellSetOption.Corrections applied to either of the below, if exist:
epsilon | Turbulent kinetic energy dissipation rate [m2/s3] omega | Specific dissipation rate [1/s]
Required fields:
epsilon/omega | Dissipation rate OR Spec. dissipation rate [m2/s3]/[1/s] plantCd | Plant canopy drag coefficient [-] leafAreaDensity | Leaf area density [1/m]
The model expression for epsilon:
\[ S_p -= \alpha \rho \left( C_1 - C_2 \right) C_{canopy} \epsilon \]
with ([69], Eq. 42):
\[ C_{canopy} = 12.0 \sqrt{C_\mu} C_d {LAD} |\u_o| \]
The model expression for omega:
\[ S_p -= \alpha \rho \left( \gamma - \beta \right) C_{canopy} \omega \]
where
| \( S_p \) | = | Source term without boundary conditions |
| \( C_1 \) | = | Model constant (epsilon-based models) [-] |
| \( C_2 \) | = | Model constant (epsilon-based models) [-] |
| \( \beta \) | = | Model constant (omega-based models) [-] |
| \( \gamma \) | = | Model constant (omega-based models) [-] |
| \( \epsilon \) | = | Turbulent kinetic energy dissipation rate (Current iteration) [m2/s3] |
| \( \omega \) | = | Specific dissipation rate (Current iteration) [1/s] |
| \( C_d \) | = | Plant canopy drag coefficient [-] |
| \( {LAD} \) | = | Leaf area density [1/m] |
| \( \u_o \) | = | Previous-iteration velocity field [m/s] |
| \( C_{canopy} \) | = | Plant canopy term |
| \( \alpha \) | = | Phase fraction in multiphase computations, otherwise equals to 1 |
| \( \rho \) | = | Fluid density in compressible computations, otherwise equals to 1 |
atmPlantCanopyTurbSource1
type atmPlantCanopyTurbSource;
atmPlantCanopyTurbSourceCoeffs
selectionMode all;
rho rho;
| type | Type name: atmPlantCanopyTurbSource | word | yes | - |
cellSetOptionTutorials
Source code
