atmPlantCanopyUSource applies sources on velocity, i.e. U, to incorporate effects of plant canopy for atmospheric boundary layer modelling.atmPlantCanopyUSource can be applied on any RAS turbulence model.atmPlantCanopyUSource inherits the traits of the fvOption, and cellSetOption.Corrections applied to:
U | Velocity [m/s]
Required fields:
U | Velocity [m/s] plantCd | Plant canopy drag coefficient [-] leafAreaDensity | Leaf area density [1/m]
The model expression ([69], Eq. 42):
\[ S_p -= \alpha \rho \left( C_d {LAD} |\u_o| \right) \u \]
where
| \( f_M \) | = | fvMatrix of the velocity field |
| \( C_d \) | = | Plant canopy drag coefficient [-] |
| \( {LAD} \) | = | Leaf area density [1/m] |
| \( \u_o \) | = | Previous-iteration velocity field [m/s] |
| \( \alpha \) | = | Phase fraction in multiphase computations, otherwise equals to 1 |
| \( \rho \) | = | Fluid density in compressible computations, otherwise equals to 1 |
atmPlantCanopyUSource1
type atmPlantCanopyUSource;
atmPlantCanopyUSourceCoeffs
selectionMode all;
rho rho;
| type | Type name: atmPlantCanopyUSource | word | yes | - |
cellSetOptionTutorials
Source code
