Time schemes define how a property is integrated as a function of time, i.e.
\[ \ddt{\phi} \]
Depending on the choice of scheme, field values at previous time steps are required, represented in the following as \( \old{\phi} \) and \( \oldold{\phi} \) for the old and old-old time levels.
Time scheme properties are input in the fvSchemes file under the ddtSchemes sub-dictionary using the syntax:
Available time schemes include
See this example to see the relative performance of the schemes.
Copyright © 2016 OpenCFD Ltd.
