By default, cases will run until the time settings are achieved in the case controlDict dictionary. Alternatively, the residualControl object can be added to the fvSolution dictionary to enable additional controls. This operates in two modes:
To terminate the case when the initial residual of the field equations falls below user-specified threshold values for SIMPLE-based solvers:
residualControl
p 1e-2;
"(Ux Uy)" 1e-4;
"(k|epsilon|omega)" 1e-4;
To control the number of outer corrector iterations for PIMPLE-based solvers:
// Maximum number of outer correctors
nOuterCorrectors 50;
residualControl
"(U|k|epsilon|omega)"
relTol 0;
tolerance 1e-4;
