This section describes the linear solver options available to solve the matrix system
\[ \mat{A} \vec{x} = \vec{b} \]
where
| \( \mat{A} \) | = | coefficient matrix |
| \( \vec{x} \) | = | vector of unknowns |
| \( \vec{b} \) | = | source vector |
If the coefficient matrix only has values on its diagonal, the solution vector can be obtained inverting the matrix system:
\[ \vec{x} = \mat{A}^{-1} \vec{b} \]
Where the inverse of the diagonal matrix is simply:
\[ \mat{A}^{-1} = \frac{1}{\mathrm{diag}(\mat{A})} \]
This is available as the diagonalSolver. More typically the matrix cannot be inverted easily and the system is solved using iterative methods, as described in the following sections.
Solver options include:
minIter: minimum number of solver iterationsmaxIter: maximum number of solver iterationsnSweeps: number of solver iterations between checks for solver convergenceMatrix coefficients are stored in upper-triangular order
Copyright © 2016 OpenCFD Ltd.
