Under relaxation factors are applied to stabilise calculations by limiting the rate of change of both fields and equations.
\[ Q^n = Q^o + \alpha \left( Q - Q^o \right) \]
The linear solvers require that the coefficient matrix is at least diagonally equal, and preferably diagonally dominant, i.e. per row, the magnitude of the diagonal must be greater than or equal to the sum of the off-diagonal components.
Specified in the fvSolution file under the relaxationFactors sub-dictionary
relaxationFactors
fields
equations
Values relate to
Copyright © 2016 OpenCFD Ltd.
