| Pre-processing
applyBoundaryLayer |
Apply a simplified boundary-layer model to the velocity and
turbulence fields based on the 1/7th power-law |
boxTurb |
Create a box of divergence-free turbulence conforming to a
given energy spectrum |
changeDictionary |
Utility to change dictionary entries, e.g. can be used to change
the patch type in the field and polyMesh/boundary files |
createBoxTurb |
Create a box of isotropic turbulence based on a user-specified
energy spectrum |
createExternalCoupledPatchGeometry |
Generate the patch geometry (points and faces) for use with
the externalCoupled functionObject |
createZeroDirectory |
Creates a zero directory with fields appropriate for the chosen
solver and turbulence model. Operates on both single and
multi-region cases |
dsmcInitialise |
Initialise a case for dsmcFoam by reading the initialisation
dictionary system/dsmcInitialise |
engineSwirl |
Generate a swirl flow for engine calculations |
faceAgglomerate |
Agglomerate boundary faces using the
pairPatchAgglomeration algorithm |
foamUpgradeCyclics |
Tool to upgrade mesh and fields for split cyclics |
mapFields |
Maps volume fields from one mesh to another, reading and
interpolating all fields present in the time directory of both
cases |
mapFieldsPar |
cases |
mdInitialise |
Initialises fields for a molecular dynamics (MD) simulation |
PDRsetFields |
Preparation of fields for PDRFoam |
setAlphaField |
Uses isoCutCell to create a volume fraction field from either
a cylinder, a sphere or a plane |
setExprBoundaryFields |
Set boundary values using an expression |
setExprFields |
Set values on a selected set of cells/patch-faces via a
dictionary |
setFields |
dictionary |
viewFactorsGen |
View factors are calculated based on a face agglomeration
array (finalAgglom generated by faceAgglomerate utility) |
wallFunctionTable |
Generates a table suitable for use by tabulated wall functions |
| Mesh generation
blockMesh |
A multi-block mesh generator |
extrude2DMesh |
Create a 3D mesh by extruding a 2D mesh with specified
thickness. For the 2D mesh, all faces are 2 points only, no
front and back faces |
foamyHexMesh |
Conformal Voronoi automatic mesh generator |
foamyHexMeshBackgroundMesh |
Writes out background mesh as constructed by
foamyHexMesh and constructs distanceSurface |
foamyHexMeshSurfaceSimplify |
Simplifies surfaces by resampling |
foamyQuadMesh |
Conformal-Voronoi 2D extruding automatic mesher with grid
or read initial points and point position relaxation with
optional ”squarification” |
PDRblockMesh |
A specialized single-block mesh generator for a rectilinear
mesh in x-y-z |
snappyHexMesh |
Automatic split hex mesher. Refines and snaps to surface |
| Mesh conversion
ansysToFoam |
Convert an ANSYS input mesh file (exported from I-DEAS) to
OpenFOAM format |
ccmToFoam |
Reads CCM files as written by PROSTAR/STARCCM and
writes an OPENOpenFOAM polyMesh |
foamToCcm |
Translates OPENOpenFOAM mesh and/or results to CCM
format |
cfx4ToFoam |
Convert a CFX 4 mesh to OpenFOAM format |
datToFoam |
Reads in a datToFoam mesh file and outputs a points file.
Used in conjunction with blockMesh |
fireToFoam |
Convert AVL/FIRE polyhedral mesh to OpenFOAM format |
fluent3DMeshToFoam |
Convert a Fluent mesh to OpenFOAM format |
fluentMeshToFoam |
Convert a Fluent mesh to OpenFOAM format, including
multiple region and region boundary handling |
foamMeshToFluent |
Write an OpenFOAM mesh in Fluent mesh format |
foamToFireMesh |
Write an OpenFOAM mesh in AVL/FIRE fpma format |
foamToStarMesh |
Write an OpenFOAM mesh in STARCD/PROSTAR (v4)
bnd/cel/vrt format |
foamToSurface |
Extract boundaries from an OpenFOAM mesh and write in a
surface format |
gambitToFoam |
Convert a GAMBIT mesh to OpenFOAM format |
gmshToFoam |
Reads .msh file as written by Gmsh |
ideasUnvToFoam |
I-Deas unv format mesh conversion |
kivaToFoam |
Convert a KIVA grid to OpenFOAM |
mshToFoam |
Convert .msh file generated by the Adventure system |
netgenNeutralToFoam |
Convert a neutral file format (Netgen v4.4) to OpenFOAM |
plot3dToFoam |
Plot3d mesh (ascii/formatted format) converter |
star4ToFoam |
Convert a STARCD/PROSTAR (v4) mesh into OpenFOAM
format |
tetgenToFoam |
Convert tetgen .ele and .node and .face files to an OpenFOAM
mesh |
vtkUnstructuredToFoam |
Convert legacy VTK file (ascii) containing an unstructured
grid to an OpenFOAM mesh without boundary information |
writeMeshObj |
For mesh debugging: writes mesh as three separate OBJ files |
| Mesh manipulation
attachMesh |
Attach topologically detached mesh using prescribed mesh
modifiers |
autoPatch |
Divides external faces into patches based on (user supplied)
feature angle |
checkMesh |
Checks validity of a mesh |
createBaffles |
Makes internal faces into boundary faces. Does not duplicate
points, unlike mergeOrSplitBaffles |
createPatch |
Create patches out of selected boundary faces, which are
either from existing patches or from a faceSet |
deformedGeom |
Deforms a polyMesh using a displacement field U and a scaling
factor supplied as an argument |
flattenMesh |
Flattens the front and back planes of a 2D cartesian mesh |
insideCells |
Create a cellSet for cells with their centres ’inside’ the defined
surface. Requires surface to be closed and singly connected |
mergeMeshes |
Merges two meshes |
Detects boundary faces that share points (baffles). Either
merges them or duplicate the points |
mirrorMesh |
Mirrors a mesh around a given plane |
moveDynamicMesh |
Mesh motion and topological mesh changes utility |
moveEngineMesh |
Solver for moving meshes for engine calculations |
moveMesh |
A solver utility for moving meshes |
objToVTK |
Read obj line (not surface) file and convert into legacy VTK
file |
orientFaceZone |
Corrects the orientation of faceZone |
polyDualMesh |
Creates the dual of a polyMesh, adhering to all the feature
and patch edges |
refineMesh |
Utility to refine cells in multiple directions |
renumberMesh |
Renumbers the cell list in order to reduce the bandwidth,
reading and renumbering all fields from all the time directories |
rotateMesh |
Rotates the mesh and fields from the direction to
direction |
setSet |
Manipulate a cell/face/point Set or Zone interactively |
setsToZones |
Add pointZones/faceZones/cellZones to the mesh from similar
named pointSets/faceSets/cellSets |
singleCellMesh |
Reads all fields and maps them to a mesh with all internal
faces removed (singleCellFvMesh) which gets written to
region ”singleCell” |
splitMesh |
Splits mesh by making internal faces external. Uses
attachDetach |
splitMeshRegions |
Splits mesh into multiple regions |
stitchMesh |
’Stitches’ a mesh |
subsetMesh |
Create a mesh subset for a particular region of interest based
on a cellSet or cellZone |
topoSet |
Operates on cellSets/faceSets/pointSets through a dictionary,
normally system/topoSetDict |
transformPoints |
Transforms the mesh points in the polyMesh directory
according to the translate, rotate and scale options |
zipUpMesh |
Reads in a mesh with hanging vertices and ’zips’ up the cells
to guarantee that all polyhedral cells of valid shape are closed |
| Other mesh tools
collapseEdges |
Collapses short edges and combines edges that are in line |
combinePatchFaces |
Checks for multiple patch faces on the same cell and combines
them. Multiple patch faces can result from e.g. removal of
refined neighbouring cells, leaving 4 exposed faces with same
owner |
modifyMesh |
Manipulate mesh elements |
PDRMesh |
Mesh and field preparation utility for PDR type simulations |
refineHexMesh |
Refine a hex mesh by 2x2x2 cell splitting for the specified
cellSet |
refinementLevel |
Attempt to determine the refinement levels of a refined
cartesian mesh. Run before snapping |
refineWallLayer |
Refine cells next to specified patches |
removeFaces |
Remove faces specified in faceSet by combining cells on both
sides |
selectCells |
Select cells in relation to surface |
snappyRefineMesh |
Refine cells near to a surface |
splitCells |
Utility to split cells with flat faces |
| Finite area
checkFaMesh |
Check a finiteArea mesh |
makeFaMesh |
A mesh generator for finiteArea mesh |
| Post-processing
noise |
Perform noise analysis of pressure data |
postProcess |
Execute the set of functionObjects specified in the selected
dictionary (which defaults to system/controlDict) or on the
command-line for the selected set of times on the selected set
of fields |
| Post-processing graphics
| Post-processing data converters
foamDataToFluent |
Translate OpenFOAM data to Fluent format |
foamToEnsight |
Translate OpenFOAM data to EnSight format. An Ensight
part is created for the internalMesh and for each patch |
foamToEnsightParts |
Translate OpenFOAM data to Ensight format with an
Ensight part for each cellZone and patch |
foamToGMV |
Translate OpenFOAM output to GMV readable files |
foamToTetDualMesh |
Convert polyMesh results to tetDualMesh |
foamToVTK |
General OpenFOAM to VTK file writer |
smapToFoam |
Translate a STARCD SMAP data file into OpenFOAM field
format |
| Post-processing Lagrangian simulation
particleTracks |
Generate a legacy VTK file of particle tracks for cases that
were computed using a tracked-parcel-type cloud |
steadyParticleTracks |
were computed using a steady-state cloud |
| Post-processing lumped-mass simulation
lumpedPointForces |
Extract force/moment information from existing calculations
based on the segmentation of the pressure integration zones |
lumpedPointMovement |
This utility can be used to produce VTK files to visualize the
response points/rotations and the corresponding movement of
the building surfaces |
lumpedPointZones |
Produce a VTK PolyData file lumpedPointZones.vtp in which
the segmentation of the pressure integration zones can be
visualized for diagnostic purposes. Does not use external
coupling |
| Miscellaneous post-processing
engineCompRatio |
Calculate the engine geometric compression ratio |
pdfPlot |
Generate a graph of a probability distribution function |
postChannel |
Post-process data from channel flow calculations |
profilingSummary |
Collects information from profiling files in the processor
sub-directories and summarizes the number of calls and time
spent as max/avg/min values. If the values are identical for
all processes, only a single value is written |
temporalInterpolate |
Interpolate fields between time-steps e.g. for animation |
| Noise post-processing
noise |
| Post-processing utility
postProcess |
of fields |
| Surface mesh (e.g. STL) tools
surfaceAdd |
Add two surfaces. Does geometric merge on points. Does not
check for overlapping/intersecting triangles |
surfaceBooleanFeatures |
Generates the extendedFeatureEdgeMesh for the interface
between a boolean operation on two surfaces |
surfaceCheck |
Check geometric and topological quality of a surface |
surfaceClean |
Utility to clean surfaces |
surfaceCoarsen |
Surface coarsening using ’bunnylod’ |
surfaceConvert |
Converts from one surface mesh format to another |
surfaceFeatureConvert |
Convert between edgeMesh formats |
surfaceFeatureExtract |
Extracts and writes surface features to file. All but the basic
feature extraction is a work-in-progress |
surfaceFind |
Finds nearest face and vertex. Uses a zero origin unless
otherwise specified |
surfaceHookUp |
Find close open edges and stitches the surface along them |
surfaceInertia |
Calculates the inertia tensor, principal axes and moments of
a command line specified triSurface |
surfaceInflate |
Inflates surface. WIP. Checks for overlaps and locally lowers
inflation distance |
surfaceLambdaMuSmooth |
Smooth a surface using lambda/mu smoothing |
surfaceMeshConvert |
Convert between surface formats with optional scaling or
transformations (rotate/translate) on a coordinateSystem |
surfaceMeshExport |
Export from surfMesh to various third-party surface formats
with optional scaling or transformations (rotate/translate) on
surfaceMeshExtract |
Extract patch or faceZone surfaces from a polyMesh.
Depending on output surface format triangulates faces |
surfaceMeshImport |
Import from various third-party surface formats into surfMesh
surfaceMeshInfo |
Miscellaneous information about surface meshes. To simplify
parsing of the output, the normal banner information is
suppressed |
surfaceOrient |
Set normal consistent with respect to a user provided ’outside’
point. If the -inside option is used the point is considered
inside |
surfacePatch |
Patches (regionises) a surface using a user-selectable method |
surfacePointMerge |
Merges points on surface if they are within absolute distance.
Since absolute distance use with care! |
surfaceRedistributePar |
(Re)distribution of triSurface. Either takes an undecomposed
surface or an already decomposed surface and redistributes it
so that each processor has all triangles that overlap its mesh |
surfaceRefineRedGreen |
Refine by splitting all three edges of triangle (’red’ refinement) |
surfaceSplitByPatch |
Writes regions of triSurface to separate files |
surfaceSplitByTopology |
Strips any baffle parts of a surface |
surfaceSplitNonManifolds |
Takes multiply connected surface and tries to split surface at
multiply connected edges by duplicating points |
surfaceSubset |
A surface analysis tool that subsets the triSurface to choose
a region of interest. Based on subsetMesh |
surfaceToPatch |
Reads surface and applies surface regioning to a mesh. Uses
boundaryMesh to do the hard work |
surfaceTransformPoints |
Transform (scale/rotate) a surface. Like transformPoints but
for surfaces |
| Parallel processing
decomposePar |
Automatically decomposes a mesh and fields of a case for
parallel execution of OpenFOAM |
reconstructPar |
Reconstructs fields of a case that is decomposed for parallel
reconstructParMesh |
Reconstructs a mesh using geometric information only |
redistributePar |
Redistributes existing decomposed mesh and fields according
to the current settings in the decomposeParDict file |
| Thermophysical-related utilities
adiabaticFlameT |
Calculate adiabatic flame temperature for a given fuel over a
range of unburnt temperatures and equivalence ratios |
chemkinToFoam |
Convert CHEMKIN 3 thermodynamics and reaction data files
into OpenFOAM format |
equilibriumCO |
Calculate the equilibrium level of carbon monoxide |
equilibriumFlameT |
Calculate the equilibrium flame temperature for a given fuel
and pressure for a range of unburnt gas temperatures and
equivalence ratios. Includes the effects of dissociation on ,
and |
mixtureAdiabaticFlameT |
Calculate adiabatic flame temperature for a given mixture at
a given temperature |
| Miscellaneous utilities
foamDictionary |
Interrogate and manipulate dictionaries |
foamFormatConvert |
Converts all IOobjects associated with a case into the format
specified in the controlDict |
foamHelp |
Top level wrapper utility around foam help utilities |
foamListRegions |
List regions from constant/regionProperties |
foamListTimes |
List times using the timeSelector, or use to remove selected
time directories |
foamRestoreFields |
Restore field names by removing the ending. The fields
are selected automatically or can be specified as optional
command arguments |
addr2line |
A simple, partial emulation of addr2line utility for Mac-OS |
patchSummary |
Write field and boundary condition info for each patch at each
requested time instance |
Table A.2: Standard utilities.
