OpenFOAM® v1612+: New Meshing Functionality
snappyHexMesh: updated locations in mesh
To seed multiple locations as volume regions to be meshed, the locationsInMesh keyword was first introduced in OpenFOAM-v3.0+. This has been improved, and the snappyMultiRegionHeater tutorial updated to show an example of its application.
The case includes five regions, whose locations in mesh are specified using:
(( 0.005 0.005 0.005) heater)
(( 0.05 0.005 0.005) rightSolid)
((-0.05 0.005 0.005) leftSolid)
((-0.05 0.015 0.005) topAir)
((-0.05 -0.015 0.005) bottomAir)
For the example case shown, this leads to the following mesh regions:
![[Picture]](img/meshing-snappy-locations-in-mesh-small.png)
- Source code
- $FOAM_UTILITIES/mesh/generation/snappyHexMesh
- Examples
- $FOAM_TUTORIALS/heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater
snappyHexMesh: new region support
A new -region option has been added to snappyHexMesh to enable region-wise meshing:
$FOAM_CASE/system/<regionName>
- Source code
- Examples
Updated renumber mesh utility
The renumberMesh utility has been extended to enable renumbering of set information.
Cell, face and point sets are generated by many pre-processing utilities, typically to gain a more detailed insight into specific mesh regions, or to isolate regions for input into subsequent set-up phases. In prior releases this information was not updated during the renumbering, leading to inconsistent addressing and unpredictable behaviour.
- Source code
- $FOAM_UTILITIES/mesh/manipulation/renumberMesh
Updated surface check utility
The surfaceCheck utility has been extended to limit excessive output of OBJ files
In previous versions a separate OBJ file was written for each problematic part, with the potential to generate a huge number of files. By default, the utility limits the number of output files to ten. This is controlled using the new -outputThreshold command line option, e.g. for the $FOAM_TUTORIALS/incompressible/simpleFoam/motorBike tutorial the following commands:
- Source code
- $FOAM_UTILITIES/surface/surfaceCheck
