OpenFOAM® v1612+: Post-processing
New extraction of particle data from multiphase
The new extractEulerianParticles function object derives particle data from fluid elements traversing a face zone during multiphase flow calculations.
Particle data is stored as a Lagrangian cloud, where the particle properties include:
- soi: start of injection
- d: diameter
- U: volume-averaged velocity
- x: volume-averaged position
This is written to the case time directories, under the name: $FOAM_CASE/<time>/lagrangian/eulerianCloud
The following example shows the lagrangian particles being collected as the liquid phase crosses the external boundaries of the Eulerian case.
type extractEulerianParticles;
libs ("libfieldFunctionObjects.so");
writeControl writeTime;
faceZone collector;
alpha alpha.water;
nLocations 20;
- Source code
- $FOAM_SRC/functionObjects/field/extractEulerianParticles
- Examples
- $FOAM_TUTORIALS/multiphase/interFoam/laminar/vofToLagrangian/eulerianInjection
New thermocouple function object
The new thermocouple function object incorporates the effects of bead thermal inertia, convective and radiative heat transfer. The reported temperature is based on an energy balance for the thermocouple bead, given by:
where
, and
represent the mass density, heat
capacity, volume, surface, and emissivity of the thermocouple bead.
is the
thermocouple bead temperature,
the local gas temperature from the cell,
the average irradiation received by the thermocouple bead, and
the
Stefan-Boltzmann constant. The convective heat transfer coefficient,
, is based
on the Nusselt number around a sphere:
Example usage:
type thermoCoupleProbes;
libs ("libutilityFunctionObjects.so");
// ODE solver properties (see $FOAM_SRC/ODE/ODESolvers)
solver rodas23;
absTol 1e-12;
relTol 1e-8;
interpolationScheme cellPoint;
// Thermocouple properties
rho 8908;
Cp 440;
d 1e-3; // diameter
epsilon 0.85; // emissivity
// Name of the incident radiation flux
radiationField G;
probeLocations
(0.5 0.5 0.5)
fields (T);
In this example the output is written to the file: $FOAM_CASE/postProcessing/probes/0/T
- Source code
- $FOAM_SRC/functionObjects/utilities/thermoCoupleProbes
- Examples
- $FOAM_TUTORIALS/combustion/fireFoam/LES/compartmentFire
$FOAM_TUTORIALS/heatTransfer/buoyantPimpleFoam/thermocoupleTestCase
New function object to generate particle distributions
The new particleDistribution function object generates distributions for user selected particle fields.
Example usage:
type particleDistribution;
cloud sprayCloud;
nameVsBinWidth
(d 1e-5)
(U 10)
setFormat raw;
- Source code
- $FOAM_SRC/functionObjects/field/particleDistribution
- Examples
- $FOAM_TUTORIALS/lagrangian/sprayFoam/aachenBomb
New flux calculation
The new flux function object generates a scalar surface flux field by interpolating the selected field to the faces, and performing the dot product with the face areas.
The object is specified using:
type flux;
field (U);
Note that the operation is limited to volVectorField and surfaceVectorField field types.
- Source code
- $FOAM_SRC/functionObjects/field/flux
Updated run-time image generation
The runTimePostProcessing function object was introduced in version v3.0+ to generate images during run-time. This has been improved to:
- optionally remove source VTK objects after use
- simplified the camera input
- new optional zoom controls
- Source code
- $FOAM_SRC/functionObjects/graphics/runTimePostProcessing
- Examples
- $FOAM_TUTORIALS/incompressible/pisoFoam/LES/motorBike/motorBike
Updated noise analysis functionality
The pointNoise and surfaceNoise models have been extended to operate on multiple input files.
Point noise example usage:
inputFiles ("$FOAM_CASE/pressureData" "pressureData2");
// Note: no file names required when specifying the pressure data
// - assuming all files follow the same schema
pressureData
nHeaderLine 0;
refColumn 0;
componentColumns (1);
separator " ";
mergeSeparators yes;
windowModel Hanning;
HanningCoeffs
// Window overlap percentage
overlapPercent 50;
symmetric yes;
Surface noise example usage:
reader ensight;
// Surface writer
writer ensight;
// Optional list of input files
inputFiles ("$FOAM_CASE/pressureData.case" "pressureData2.case");
HanningCoeffs
overlapPercent 50;
symmetric yes;
- Source code
$FOAM_SRC/randomProcesses/noise/noiseModels/pointNoise
$FOAM_SRC/randomProcesses/noise/noiseModels/surfaceNoise
New scalar zero gradient function object
The new zeroGradient function object projects the patch internal field values on to the patch faces. This is a simpler alternative to the nearWallFields function object for the case that only the cell values adjacent to the patch are of interest.
The input fields are selected via a wordReList, e.g.
The names of the resulting output fields use place holder tokens for flexibility, e.g.
The @@ place holder is replaced by the name of the input field, e.g.
result zeroGradient(@@);
-> zeroGradient(U), zeroGradient(T)
Or,
result @@nearWall;
-> UnearWall, TnearWall
- Source code
- $FOAM_SRC/functionObjects/field/zeroGradient
