The velocity is modelled according to the equation
\[ \div \tensor{R}_{dev} = \grad p + S_U \]
where the velocity and pressure gradient are corrected to achieve the target velocity \( \overline{\u} \). After solving the above equation, the velocity is corrected from the current volume-averaged velocity, i.e.
\[ \u^{n+1} = \u^n + \left( \overline{\u} - \overline{\u}^n \right) \]
and the pressure gradient from:
\[ \left(\grad p\right)^{n+1} = \left(\grad p\right)^{n} + \overline{\frac{1}{\mat{A}}\left( \overline{\u} - \overline{\u}^n \right)} \]
where the averages are calculated as volume averages.
Mandatory fields:
constant/turbulencePropertiesconstant/fvOptions (optional)Source code
See also
Tutorials
Copyright © 2018 OpenCFD Ltd.
